Message 1 of 6
BT Smart Hub 2 - Other IP Address Range
I have recently upgraded to FTTP.
I have a 3rd party router (planned to remove), my home network is on 10.153.28.1/24
When I have tried to change the Smart Hub 2 IPV4 to this IP address and DHCP Range I get an error
"These IP settings are not valid on the hub"
5 REPLIES 5
Message 2 of 6
Re: BT Smart Hub 2 - Other IP Address Range
Did you also change the gateway address?
Message 3 of 6
yes
Message 4 of 6
The range is reserved on the Smart Hub 2, for the BT WIFI public hotspot.
Message 5 of 6
Many thanks - much appreciated
Message 6 of 6
Follow on:
@tkei is there a list of IP ranges that are excluded?
