Message 1 of 2
Ethernet Connection
Just had full fibre installed and my smart hub has had to move over to the other side of the room for the new set up. I'm trying to connect to my Internet through my TV but it keeps saying the ethernet cable needs connecting to my youview box. Does it need to be connected or can I get it wirelessly hooked up?
1 REPLY 1
Message 2 of 2
Re: Ethernet Connection
If you have a Pro Box, it will work over WiFi but any other BT Youview boxes will need to be wired.
