Message 1 of 6
BT Smart Hub 2 & single band devices
Hi All,
Recently upgraded to Fiber to the house.  Received the latest Smart Hub 2, and I'm having difficulites with a few devices.
Kindle (paperwhite 10th gen) device wouldn't connect, kept saying password was incorrect.
Logitech Harmony Hub, wouldn't be discovered by Android or Windows app.
I kind of fixed both of these issues by turning 5Ghz off, and retrying.
The Harmony hub worked (inc. with Alexa) until I re-enabled 5Gz, it now isn't discovered by either Windows or Android again.
The Kindle connected when the network was 2.4Ghz only and at the time of writing i've not re-enabled 5Ghz, but I'm not holding my breath for it to continue working when I do re-enable.
So...my question firstly does anyone have a fix within the Smart Hub2, some setting I may have missed that would make these devices work as they should?
Alternatively is there an alternative to the Smart Hub2, either using a router/modem or just pairing the hub with a wifi router?
TIA
tibbi1m
5 REPLIES 5
Message 2 of 6
Re: BT Smart Hub 2 & single band devices
@Tibbi1m
The simplest option would be a separate 2.4GHz wireless access point plugged into a home hub Ethernet port. Give it a different SSID.
Like this one https://www.tp-link.com/uk/home-networking/access-point/tl-wa901n/
Message 3 of 6
Thanks, but do I then suffer from double NAT?  I'll still want hard wired things into the Smart Hub (specifically Sky Q which is rubish with BT apparently, and Hive Hub which only has a wired connection).
Message 4 of 6
There are no settings within the SH2 that you can make.
The simplest solution is to add a cheap 2.4Ghz wireless access point connect it to the hub and turn off the 2.4Ghz on the hub. That way you will have different SSIDs for the 2 bands.
Message 5 of 6
No, you will be connecting it LAN to LAN as a WAP, not LAN to WAN as a router.
Message 6 of 6
@Tibbi1m
I use a SH2 and have SKYQ which works over WiFi without a problem however I have changed the 5ghz WiFi channel to channel 44 as channel 36 is used by SKYQ
