Over the past 2 weeks my Smart Hub 2 keeps disconnecting and reconnecting, it's really annoying. I spoke to BT and they changed 2.4GHz and 5GHz channels and set the hub back to factory settings. Made no difference, so I contacted BT again and they sent me a new hub, which I have now set up. However it is still disconnecting! Does anyone have any advise please?
Are the hub lights changing colour? If so what colour?
Is your connection FTTC or FTTP?
Hub lights changing colour?
Have you tried connecting to test socket instead of socket front plate?
Your posting history shows you had what appears to have been be a very similar issue around a year ago , that thread never had a conclusion , but presumably the issue was resolved, so what was the ‘fix’ or did the problem mysteriously just disappear ?
I cant really remember but this issue started around 2 weeks ago and its worse than ever!
Sounds like you have a line fault.
