Message 1 of 8
BT Smart Hub 2 keeps disconnecting
Over the past 2  weeks my Smart Hub 2 keeps disconnecting and reconnecting, it's really annoying.  I spoke to BT and they changed 2.4GHz  and 5GHz channels and set the hub back to factory settings.  Made no difference, so I contacted BT again and they sent me a new hub, which I have now set up.  However it is still disconnecting!  Does anyone have any advise please?
7 REPLIES 7
Message 2 of 8
Re: BT Smart Hub 2 keeps disconnecting
Are the hub lights changing colour? If so what colour?
Is your connection FTTC or FTTP?
Message 3 of 8
Thanks for your reply, its Fibre to cabinet
Message 4 of 8
Hub lights changing colour?
Have you tried connecting to test socket instead of socket front plate?
Message 5 of 8
Your posting history shows you had what appears to have been be a very similar issue around a year ago , that thread never had a conclusion , but presumably the issue was resolved, so what was the ‘fix’ or did the problem mysteriously just disappear ?
Message 6 of 8
I cant really remember but this issue started around 2 weeks ago and its worse than ever!
Message 7 of 8
hub lights flash orange then back to blue
Message 8 of 8
Sounds like you have a line fault.
