Message 11 of 15
Re: BT Smart Hub 2
Very helpful to know. My install is probly in July, and I have Sky Q and 4 mini boxes.
I was wondering why are there only a few channels usable?
Also, when a chanel is changed to a better channel, do you have to turn off smart switch to stop it changing back?
Thanks.
Message 12 of 15
Re: BT Smart Hub 2
Yes, you will have to turn the Smart off.
As far as the number of channels goes, there are only really 1, 6 and 11 at 2.4GHz because the channels are so close together, they interfere with each other.  An oversight in the original design.  Only 1, 6 and 11 are far enough apart to be completely separate.
At 5GHz they are already set four channels apart but the airwaves are crowded and your Wi-Fi is not the only thing out there.  Channels above 48 can be used but they may clash with things like radar and so are obliged to use DFS (Dynamic Frequency Selection) and jump to another channel if they detect a radar signal etc.  This means 36, 40, 44 and 48 tend to be the most stable for home use.
Message 13 of 15
Re: BT Smart Hub 2
Ok, thanks for that. Regards.
Message 14 of 15
Re: BT Smart Hub 2
The options are Smart or individual channels, ergo setting a channel disables Smart.
Message 15 of 15
Re: BT Smart Hub 2
