Message 11 of 31
Re: BT Smart Hub 2 Alternative
Moved house and had fibre to the door option so had a new BT Smart Hub 2 router supplied. As you know it only has 3 available. Current connectivity:
Router port
1 Gigabit switch
2 BT halo WiFi extender
3 Electric gates
Netgear Switch
Port
1 NAS
2 Shed
3 Ring Network
The Netgear connectivity to my shed connects to a Cisco POE switch that supports 4 x Network cameras.
Message 12 of 31
Forgot to say I need another router connection hence my problem.
Message 13 of 31
If it's as straight forward as you've described and your old router has a WAN port you should just be able to carry on using that.  The only time you can't escape using the Smart Hub 2 (SH2) is if you need Digital Voice, as that has to go through the SH2.
Edit: ...but again, you haven't explained why you feel you need another router?
Message 14 of 31
Exactly, why do you need more ports on the router when you can have as many as you like on a switch(es)?
Message 15 of 31
The trouble is people say things on here without really understanding what they are saying.  So, if you do need two routers the implication is that you have two internet connections?  Is that for load balancing or failover?
Message 16 of 31
If cost is not an issue TP link do a 28 Port POE switch on Amazon for £180 which should more than cover your needs.
Message 17 of 31
It would help if the exact problem was described.
Message 18 of 31
Having pondered what you’ve said so far, I think you really just need another switch, not a “router”.  (The “router” provided in the domestic market is a cheapo multipurpose box that does a number of jobs that would be separate boxes in industry.  As routing is the most significant, it gets the name router but the routing function is not what you want here, I think).
What you need (I think) is room to connect a second switch to the SH2.  It is possible to connect one switch after another in what is known as a cascade.  (Price is that it pushes latency up a little bit).  If so, I would do it this way.
Current setup:
Router port
1 to shed switch?
3 Electric gates
New setup:
Router port
1 to new switch…………………….one port on that to the shed, the other ports to what you want.
3 Electric gates
Message 19 of 31
Thank you and apologies as I didn’t explain the switch ‘reference’ properly. The Netgear switch connectivity is configured as per your ‘New Setup’. The shed Cisco switch hangs off the Netgear switch. The cameras cope well with the latency.
Message 20 of 31
Given the restrictions associated with only having 3 usable Ethernet ports I was wondering whether someone had encountered the same problem and ‘somehow’ managed to find a suitable alternative router with more usable ports.
