Message 1 of 4
BT Smart Hub2
Is it really smart? My WiFi analyzer seems to always indicate I am not on the best channel available. Any thoughts?
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub2
Yes. Turn off "Smart wireless" and manually select the least congested channel.
Message 3 of 4
Re: BT Smart Hub2
Thanks. That seems to confirm the smart hub isn't smart at all.
Message 4 of 4
Re: BT Smart Hub2
 It confirms that the smart wireless software is slow to react or uses a different parameter when to change rather than being instant which could mean it constantly changing.
In any event you can change it manually if you want although unless the channel you are on is very heavily congested  you will probably not notice any difference.
