Message 1 of 3
BT While Home Wi-fi with Smart Hub 2
I’ve recently been forced to change to a SmartHub 2 due to digital voice and now find that my white Whole Home WiFi disks are not working as well as before. One of the disks keeps dropping the connection whereas previously it has connected reliably grin the same location. Can anyone tell me if there are any settings I should change on the SmartHub 2 to improve things, or are there white disks not compatible with the Smart Hub 2? Any advice appreciated.
2 REPLIES 2
Message 2 of 3
Re: BT While Home Wi-fi with Smart Hub 2
Eithet turn off the WiFi on the hub or make sure it isn't using the same channel as the discs.
Message 3 of 3
Thank you. I’ll give that a go.
