Message 1 of 3
Hybrid connect - how does it rout on failure
On Hybrid Connect, how do WiFi sources rout to the internet when there is an incoming internet failure to the HUB ?
(please don't reply "automatically" LOL)
Thx
Scouser
2 REPLIES 2
Message 2 of 3
Re: Hybrid connect - how does it rout on failure
The Hybrid Connect simply replaces your normal broadband connection. It connects to the hub WAN internally.
Message 3 of 3
Try thinking of it as the SH2 router has two ‘paths’ to the ‘internet’ , the usual path is via the ‘landline’ broadband  and a reserve back up path is via mobile 4g , should the landline service fail , the router switches over to using the 4g service , you (or more accurately your devices) still connect to the router in the same way they always do, they don’t care if the router is using the primary  ‘path’ or the back up ‘path’ , from your device point of view , the path the router is using to the ‘internet’ doesn’t matter , they have a path …..it just may not be as fast etc as the primary path ,
