Message 1 of 3
BT WiFi Disc ‘Extender’
Hi all.
I have a Smart Hub 2 & WiFi Disc. It has never seemed to work well.
I have recently been using several Android Apps installed on my tablet to check WiFi signal strength.
When reading the app signal strength close to the Smart Hub 2 it reads 100% (which is what I would expect).
When reading the app signal strength close to the ‘Extender’ it shows the same weak signal when the Disc is on (Blue light solid) or totally switched off.
The question is Should the Extender boost the WiFi signal strength back to100% and if so how can I reset it to work?
Many thanks.
Colin
2 REPLIES 2
Message 2 of 3
Re: BT WiFi Disc ‘Extender’
It would appear that the disc is not working in that case. Did you set it up correctly?
Message 3 of 3
Licquorice.
DOH, never occured to me to go back to basics and pair the Disc and Smart Hub2
All resolved thanks.
Colin
