Message 1 of 2
BT blocked ports?
When checking if certain ports such as port 80 etc are open for gaming, im being told by  the website www.yougetsignal.com that the port is closed by the isp. Even when enabling port forwarding on my BT router, it says the port is still closed.
Why has BT blocked these common ports? Could this be why Im having issues with online gaming?
1 REPLY 1
Message 2 of 2
Re: BT blocked ports?
They are not blocked.
The port will show as closed unless there is a service running on the tested port.
