Message 1 of 8
Port Forwarding Rules
I am trying to set up a Port Forwarding Rule in the Hub Manager.  I enter all the details and click save and it says its been saved, but when I look in the firewall tab no rules are showing.  Any ideas?
7 REPLIES 7
Message 2 of 8
Re: Port Forwarding Rules
Sometimes it takes a little time or needs a restart.....odd
Message 3 of 8
I have tried many times and also restarted hub 😞
Message 4 of 8
Did you press the + symbol before save? If not, try it.
Message 5 of 8
I certainly did 😞
I then pressed save, it says it was saved  but then when i go back to firewall tab no rules are showing
Message 6 of 8
Have you tried a factory reset of the hub with the recessed button rather than a restart? Also, turn off UPnP afterwards.
Message 7 of 8
How do I   turn off  UPnP after factory reset?
Also what is UPnP?
Message 8 of 8
Advanced settings> firewall> UPnP
Universal plug and play, effectively automatic port forwarding. It can clash with manual port forwarding
