I have seen similiar questions to below - but cannot see the answer ?
I have a BT 4G hub connected to BT mesh discs. All works fine , however if I lose power to hub it will not reconnect to master disc.
If the 4G hub is conected via ethernet cable to pc will reconnect ok after repower
is the disc not sending address at the time of hub reconnection ?
Many thanks for any thoughts
Solved! Go to Solution.
