Message 1 of 5
BT is blocking access to a website
I have an issue with BT having blocking a website we have built. Its definitely a problem caused by BT and is affecting access. I only managed to access the site by changing DNS provider in browser setting from the default provider in my case this is BT to any other DNS provider then I can access the site.
Please can someone at BT unblock the domain. The URL is https://accessallarts.skyarts.uk/
Many thanks
The only way to access the site for
4 REPLIES 4
Message 2 of 5
Re: BT is blocking access to a website
See https://www.bt.com/help/security/parental-controls/i-ve-got-a-problem-with-bt-parental-controls#inco...
You can contact BT on an email link which is posted on that page,
Message 3 of 5
Works fine for me using BT DNS.
Message 4 of 5
I can also access it using BT.
Message 5 of 5
While I'm not currenty using BT DNS, Web Protect blocks the site to me.  Something that no one else has mentioned though is that the name itself is trademarked, so I wouldn't be surprised if it were difficult to keep off the blocklists or even faced a takedown request!
I only learn by making mistakes and owning up to them - boy do I learn a lot!
