Message 1 of 5
url redirect
is it possible to mkae it so when someone on my network goes to a website it redirects them to a differnt one? I.E going to youtube.com will instantly redirect you to google.com
4 REPLIES 4
Message 2 of 5
Re: url redirect
No
Message 3 of 5
Re: url redirect
well **bleep**
Message 4 of 5
Re: url redirect
Technically you can by hijacking the DNS request to your own http server and then do the redirect there but it does mean you'll need to run and maintain your own DNS nameserver and http server on your local network. There are also limitations
Message 5 of 5
Re: url redirect
If this is one particular user then you can edit the "hosts" files on their device to do this.  On some third-party routers, it's also possible once again by editing the router's own hosts files.  Yes, you can do a proper redirect, but usually, the hosts file is enough!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
