Message 1 of 4
BT wifi plus externder
Can I permanently connect my BT wifi plus extender to the hub 3 via ethernet instead of wifi?
3 REPLIES 3
Message 2 of 4
Re: BT wifi plus externder
Message 3 of 4
How do i remove it from the WiFi so that it extends via the ether cable only?
Message 4 of 4
Whilst it is connected by Ethernet it won't be connected via wifi.
