Message 1 of 1
BTsmart hub2 Ethernet connection to Sky+HD box
Hi guys
Our Sky+HD system had been working perfectly for many years with box connected to the BT broadband router via cat 6 Ethernet cable.
Just recently we upgraded to the BT home hub2 on Halo 3+ and realised that the sky+ HD box was not connected to the router.
All other devices were working fine so tried resetting the router and the Sky+HD box without succes.
I also tried a factory reset on the router and swapping over with the Fire TV Ethernet cable which also goes back to the router.
I can get connection via wifi but want the  speed and reliability of the Ethernet.
I did get the Ethernet to connect once but I hadn't done anything, we turned the TV on one morning and it had connected to Ethernet but a few minutes later it disconnected and returned to wifi.
Is this a problem that anyone else has had before or any ideas how to get the sky box onto the Ethernet connection?
