Message 1 of 3
Broad Band Cables
Have just had Firbe100 installed, the cable from the wall plate to the WAN on the router is not long enough to locate the router where I want it, is this a special cable, or will a wired cable of extended length work just as well, if not what is the spec and where can I get one please
2 REPLIES 2
Message 2 of 3
Re: Broad Band Cables
It is just an ethernet cable so cat 6 ethernet or better will be ok
Message 3 of 3
Thank you
