Message 1 of 4
Broadband Signal Booster
I have BT Broadband Fibre 1. I don't get a signal in one room. I want a signal booster. But I'm not sure what one to get. Is it BT Whole Home Wi-Fi? And how is it setup? Does it have to be wired to the router?
3 REPLIES 3
Message 2 of 4
Re: Broadband Signal Booster
@cj1967
Welcome to this user forum for BT Retail phone and broadband customers.
This would be the simplest solution.
https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220-kit/
About £40.
Normal wireless extenders are not usually any good.
Message 3 of 4
Where does the TL-WPA4220 booster go? Is it wired into the router? Or does it go in the room without the signal?
Any reason the BT WiFi discs aren't any good?
Message 4 of 4
If you look at the diagram at the link, you will see how these devices work
They basically convert your mains wiring into an Ethernet cable.
They come as a pair, one connects to your router with a short Ethernet cable, the other can be sited anywhere with a mains socket and provides both Ethernet sockets and a WiFi hotspot signal
