Message 11 of 13
Re: Broadband - master socket location
I presume the fact there are no wires on those clips mean no extensions are set up ?
Message 12 of 13
Correct. Are there any wires connected to the extension sockets?
Anonymous
Not applicable
Message 13 of 13
Doesn't look like it. You'd have to try to trace the wiring back from the extensions to see where it goes.
Is this a new build property or just new to you?
