Message 1 of 4
Bt Smarthub 2 Admin Password
Hi there,
Had a replacement hub delivered 3 weeks ago everything fine.Logged in as soon to as it was up and running and changed something.Tried to login in to advanced settings tonight  to change something and it’s already asking me to change the default password.Why would it do that after 16 days?
3 REPLIES 3
Message 2 of 4
Re: Bt Smarthub 2 Admin Password
It is a security issue. The Smarthub2 and all the recent BT hubs requires you to change the default password after you have accessed the settings for the first time. You only need to do that once.
Message 3 of 4
Deleted
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Yes I did to change 5ghz channel
