Message 11 of 18
Re: Bt homehub 2 Bridge mode
By way of an update.... speeds are much faster using SH2 (wifi off) and Asus Mesh in AP mode.
I'm getting 830 down at the SH2 hub consistently. When I connect the Asus Mesh directly to the ONT (dispensing with SH2) I am only getting 500 down.
Don't know why, but no big deal using the SH2 and Asus together.
Message 12 of 18
Thanks for the reply , I ended opting for the draytek 2927 ac which is now linked to my 7 linksys tri-band mesh system. The full fibre is being connected on Thursday. Do you still have it set to pppoe?
Message 13 of 18
I think only the Draytek needs to be set up with pppoe and the mesh can be in access point mode. At least that's how my set up is.
As an experiment I tested a couple of old Zyxel modem routers that I have. The oldest one which I got for a tenner on eBay some years ago, records speeds of just over 900 so I am using that now instead of the SH2 hub 🙂
Message 14 of 18
Yeah well that's how mine is set up with fttc but is it the same with fttp ?
Message 15 of 18
With FTTC you need to provide a copper modem as well as router, with FTTP the ONT is the modem.
Message 16 of 18
All through pppoe?
Message 17 of 18
Message 18 of 18
