Message 1 of 3
CCTV System
How do I connect a 2.4ghz wi-fi home security system to my 5ghz hub?
2 REPLIES 2
Message 2 of 3
Re: CCTV System
your hub is 2.4 and 5ghz .  if having problems then disable 5ghz in hub manager/wireless then connect CCTV then turn 5ghz back on
Message 3 of 3
Re: CCTV System
Hi Imjolly
I will try this and let you know how I get on.
Cheers
