Message 1 of 5
Cable connection between smart home hub and broadband port on master socket 5c mk4
I have a cable with rj11 connectors at both ends. Is this suitable?
4 REPLIES 4
Message 2 of 5
Re: Cable connection between smart home hub and broadband port on master socket 5c mk4
@Donnymk1
Welcome to this user forum for BT Retail phone and broadband customers.
Yes, that is what you need, it normally comes with the Smart Hub 2.
Message 3 of 5
Thanks Keith
The reason I question it is the socket looks bigger than a RJ11. I thought it may have been a RJ25.
Many thanks
Message 4 of 5
That’s RJ45 and a lot of the RJ45 sockets today will also take an RJ11.  (Although it might seem a bit loose, it will still work).
Message 5 of 5
Thanks WSH for your helpful reply
