Message 1 of 7
Can I purchase an installation of a new master socket 5c?
If so, how much? I want it installed upstairs, will the engineer have tall ladders to do this? I imagine he would have to drill a hole? The cable comes from the overhead pole.
Thank you.
6 REPLIES 6
Message 2 of 7
Re: Can I purchase an installation of a new master socket 5c?
If you're with BT for your phone/broadband, you can request a socket move, the cost is £130
Message 3 of 7
Thank you. Will the old socket have to move? Can it stay there and be decomissioned? I worry about marks on the wall if it is removed. Thank you.
@-Richie-
Message 4 of 7
It can stay there if you want or remove it next time you decorate, the engineer will simply change where the master socket is located.
Message 5 of 7
Thanks Richie. One last question, will the old socket be decomissioned, as to no longer be wired up to some data and power circuit?
I really wanted a new pure socket where the old one's wiring is not in its circuit. Just wire from the pole, to the new socket, that's it.
Thank you.
Message 6 of 7
Yes it will be decommissioned, the new one will be the master socket.
Having extensions is an additional charge, I think £65 for each one.
Message 7 of 7
Great, thanks for your help Richie!
