Message 1 of 8
Can't save new port forward setting
Hi there,
I'm trying to forward a port on my router, but when I click save it just hangs. I've tried different names, ports, and settings and nothing seems to work.
Any advice on what I could try next?
7 REPLIES 7
Message 2 of 8
Re: Can't save new port forward setting
Hi,
Which router do you mean? Do you meant the BT Smart Hub 2, or do you mean a different router that you are using?
Message 3 of 8
Factory reset the hub and start again
Message 4 of 8
Sorry yes it's the Smart Hub
Message 5 of 8
Ok, have you given Liquorice's suggestion a try?
"Factory reset the Smart hub and start again"
You can factory reset the smart hub by holding a pin in the recessed button in the back until the light on it turns green, then release.
Message 6 of 8
Sorry all, I found it... I was pressing Save, but I needed to press the little + button first to add the rule. It's working now and I feel stupid XD
Message 7 of 8
It's not intuitive
Message 8 of 8
No it isn't intuitive at all, I get confused by those settings sometimes.
