Message 1 of 4
Cannot log out of Hub Manager (no access to previous post)
Hi,
Once logged into Hub Manager there does not seem anyway to log out.  It is a security risk as anyone who finds laptop or mobile phone has full access to sensitive wifi settings.
I could not access this previous post as says I don't have permission? https://community.bt.com/t5/Archive-Staging/Log-out-of-Hub-Manager/td-p/2100554/page/2
PS; anyone having problems logging in.  I had a second mifi (mobile wifi) router.  When I switched off the second router from another provider I could access BT Hub Manager on 192.168.1.254.
I had also done a factory reset which may have helped as well.
Problem is I now cannot log out and so exposing sensitive security info.
M
3 REPLIES 3
Message 2 of 4
Re: Cannot log out of Hub Manager (no access to previous post)
What sensitive security information would this be?
Clear the cache from your device.
You can only access the hub manager from within your LAN
Message 3 of 4
Ok I now see the settings are password protected.  I was thinking about visitors gaining access.
I will clear the cache but suppose I would prefer a log out option as a tidier option.
M
Message 4 of 4
You are normally "logged out" automatically shortly after you close the management page.
