Message 1 of 12
Cannot save Smart Hub 2 admin password in Firefox or Edge
I have no problem accessing the hub manager and entering the admin password but I have to type it every time because neither browser offers to save it. Never had this problem with the old hub.
Any suggestions please?
11 REPLIES 11
Message 2 of 12
Re: Cannot save Smart Hub 2 admin password in Firefox or Edge
Firefox saves it ok for me. It is a browser/device problem, not a BT problem.
Anonymous
Not applicable
Message 3 of 12
yeah work ok for me
Anonymous
Not applicable
Message 4 of 12
have you pressed neve by ccident n the one time it asked tto save or hanged the offer to save password setting
Message 5 of 12
You can save the password manually. Go to the Firefox settings by clicking on the 3 lines at the top right hand side and click on "passwords" and click on the + beside the search box. This will open a section where you can enter the relevant details then click "save".
It is the same in Edge.
Message 6 of 12
Thanks but with both browsers the password is already saved.
My problem is that you don't need a password to open the Hub Manager only when you want admin permission (for Advanced settings etc). At that point you are asked to enter a password as usual but there is no password manager popup so I need to type it every time.
Could this be linked to the https issue below. The BT help seems to say just ignore it which I do. Obviously never happened with the old hubs.
Message 7 of 12
Have you updated the saved password since the change to HTTPS? The site will have changed from  HTTP://192.168.1.254/  to HTTPS://192.168.1.254
Message 8 of 12
Yes but Edge for example opens the Hub manager with this in the address bar:
I assume this is related to the certificate issue mentioned in the BT help page I linked. Manager still works normally except for not being able to automatically insert the admin password.
Message 9 of 12
I am starting to think the problem is linked to the way this admin login window works:
I changed the URL to https://bthomehub.home/ and that forced Edge to prompt me to save the password.
I did that but after closing the browser and reopening Hub Manager there was still no auto password completion.
Message 10 of 12
The log on is not on a separate web page, it is a dropdown box from within the Dashboard screen so I doubt that the browsers will recognise it as a webpage logon and as such it will not be able to be saved by the browser.
