Message 11 of 12
Re: Cannot save Smart Hub 2 admin password in Firefox or Edge
Saves for me in Firefox
Message 12 of 12
If you are correct that the browsers will not recognise the password entry as a logon why is it that the first time I used either URL and entered a password the browsers prompted me to save it and did so? The issue is that autofill of the saved password does not trigger.
UPDATE
In Firefox I deleted the previous saved password entries for both URLs. I then used the URLs again and saved the passwords when prompted. On subsequently using Hub Manager the password is now auto completed. 😊
Will not bother with Edge. Thanks for all the responses.
