Message 1 of 4
Cant connect to BB
My BB comes into flat in hall Master socket 5 c far away from the lounge where all my equipment is. I have hybrid connect so am using fallback ee wifi, but obviously i dont get the sports package that way, only by bb.
To check I connected hub to 5c and it works.
At present the set up i am trying this. out of the 5c via rj11 to a bt mini connector via rj45.   paired to another mini connector in the lounge then via rj45, to a yellow port at hub. This is not working, its just something i thought i would try, should it work ??
I have an extension socket in lounge which doesnt seem to be connected.
Obviously i cant have the hub in hall and cables running through the hall into the lounge
Can anyone help or advise TIA
3 REPLIES 3
Message 2 of 4
Re: Cant connect to BB
That won't work.
Put the hub in the hall and then use powerline adapters to provide WiFi and Ethernet where required.
Message 3 of 4
Cool, Any port in the hub ? Great that is now working, apart from no sports package on now box
Brilliant thank you so much licorice, appreciated.
Message 4 of 4
Yes, any port. Just make sure port 4 isn't configured for full fibre.
