Message 1 of 7
Moved Hub2
Hi
I moved my Hub 2 down one shelf on my cabinet.  When I have plugged it all back in, it's just flashing orange lights.
Any ideas?
6 REPLIES 6
Message 2 of 7
Re: Moved Hub2
Flashing orange light usually means it's connecting to broadband, on FTTC/xDSL (via the phone line) that can take a couple of minutes.  If you are on FTTP/Full Fibre, make sure that the connection to the box on  the wall is using WAN (port 4).
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 7
Re: Moved Hub2
When connected to port 4 it is flashing purple
Message 4 of 7
Re: Moved Hub2
is the router connected to phone outlet or box like this
if like one above then middle connection (yellow ethernet) should be connected to port 4 on back of hub
Message 5 of 7
Re: Moved Hub2
It's connected to a phone port only
Message 6 of 7
Re: Moved Hub2
sorry but are you sure you put cables back in the same place before you moved router
Message 7 of 7
Re: Moved Hub2
If it’s connected to the phone socket on the wall, then the other end needs to connect to the grey DSL port on the hub.
