Message 1 of 5
Change to single modem router using tp-link Archer AX72 Pro
I have full fibre 900 broadband. I have ordered tp link 1x archer ax72 pro and 2x RE815XE.
Is it possible to remove the openreach modem and just use tplink?
Can anyone explain the steps and any specific configuration setting I need to do?
Tags (3)
4 REPLIES 4
Message 2 of 5
Re: Change to single modem router using tp-link Archer AX72 Pro
No, that is not possible. The Openreach ONT is required as your service is extracted from the PON in accordance with it's serial number.
Message 3 of 5
Anonymous
Not applicable
Message 4 of 5
Did you really mean the ONT or where you referring to the BT Hub when you said "modem"?
Message 5 of 5
The ONT. Openreach modem
