Message 1 of 5
Complete Wi-Fi Plus Disc:
Broadband recently installed and extra discs to boost wifi seem to be working fine  on the allocated network and password.
However  I have set up, as offered on the system,  a "guest wifi" from the "Hub manager" with new name and password. This guest network works near the main hub...BUT not it seems from the extra discs in other rooms.
Any ideas why?
TIA
4 REPLIES 4
Message 2 of 5
Re: Complete Wi-Fi Plus Disc:
How have you managed to that, the BT hub doesn't have guest network capability.
Message 3 of 5
We are a small business...does that make a difference?
I logged on to the hub manager details on the back of the hub and it let me set up a guest wifi with password.
Set up an easy network name and easy password for guests...but only seems to connect near  the hub, not the wifi discs in other rooms.
Message 4 of 5
Makes a huge difference, the business hub is a different device to the residential hub.
You need to post on the business forum. https://business.forums.bt.com/
Message 5 of 5
Brilliant, thank you!
