Message 11 of 15
Re: Complete Wi-Fi acting as Two Networks
Seamless mesh has nothing to do with signal strength, it just means you can move around with a mobile device and it will switch between WiFi signals without a slight interruption.
Black, complete WiFi discs will accomplish that.
Message 12 of 15
If you have the white disks then the only way you can achieve one seamless mesh with one SSID is to disable the Wi-Fi on the hub
Anonymous
Not applicable
Message 13 of 15
https://www.bt.com/broadband/complete-wifi
So you should have been supplied with at least one black disc as part of your package.
Message 14 of 15
THANK YOU for all your help guys - now sorted.
I've rang BT and they are going to send me a black disk so I can have Complete Wi-fi (which I'm paying for).
My confusion was not understanding the difference between Whole Home and Complete Wi-Fi. Now I do.
Thanks again
Emyr
Anonymous
Not applicable
Message 15 of 15
If you need them, I think you can request up to three.
