Message 1 of 11
Computers not connecting on the local network
I have a Home Hub 2 with an Extender disc. I work upstairs, and have 2 computers which both connect to the disc. I am doing development where one computer runas an api process and the other runs a web front end. Obviously the coputer with the fornt end needs to connect to the one running th apoi. I also use a package called Synergy which uses the networkj to allow the mouse and keyboard on one computer to contorl the other. this setup has been working fine for 3 years.
Recently (the last 6 - 8 weeks) the computers have been losding the connectivity from time to time. At that point a ping from one machine to the other stops working. This may last for a minute or two or longer. When the machines are not talking to each other they can both access the web (via the disc and hub) with no problems. If I switch off the disc things start working again (but slowly and a bit unreliably). Usually all ok again for a while when I dwitch the dicsc back on again.
It seems there may be somehting up with the disc but BT and OpenReach both say they cannot help as it is a local neworking problem - they are only interested if broadband is not working. Despite that fact that this is all thier equipment supplied and i am paying a fortune for Halo as well.
10 REPLIES 10
Message 2 of 11
Re: Computers not connecting on the local network
Factory reset the hub, it sorts out most problems like this.
Message 3 of 11
Thanks will try that later when my wife is finished working!
Message 4 of 11
Do it physically with the recessed button at the rear of the hub rather than via the GUI. Press it for about 20 seconds until the lights flash.
Message 5 of 11
Actually should I reset the hub or the disc or both?
Message 6 of 11
Just the hub.
Message 7 of 11
Hub reset. Everything back up. Working normally so far so fingers crossed and I will let you know if it keeps going tonight and tomorrow.
Message 8 of 11
It's still cooming and going a bit - but much better than it was. May try resetting the disc too
Message 9 of 11
Hi @AlasdairR
Let us know how you get on after trying the reset. iI this continues I would suggest getting back in touch with our broadband tech guides to see if they can suggest anything else for you to try.
Leanne.
Message 10 of 11
Thanks Leanne. But this morning I can say that after advice from the venerable and distiguished sage licquorice (and resetting the disc as well as the hub) everything seems to be hunky dory again.
