Message 1 of 6
Connect usb drive to hub for networking
Have plugged usb drive into hub and is showing in Hub Manager but cannot access it via File explorer Network tab. Is there a setting I need to activate or something I need to do to enable the drive to be visible. Am using Windows 11 and the drive is plugged into the USB slot on Smart Hub 2
5 REPLIES 5
Message 2 of 6
Re: Connect usb drive to hub for networking
Map a network drive letter to \\192 168.1.254\usb1
You will also need to enable SMB1 as it is disabled by default in W11
Message 3 of 6
Hi Disc shows in Hub manager but not in File explorer, type in to map network drive in run command and says SMB1 not enabled. How do I enable SMB1 so can map the drive ?
Anonymous
Not applicable
Message 4 of 6
Message 5 of 6
You may not be able to enable SMB1 in Win11 as SMB1, I think, is a security risk and may not be available in Win11
https://learn.microsoft.com/en-us/windows-server/storage/file-server/troubleshoot/detect-enable-and-...
Message 6 of 6
It is disabled by default but is available.
I currently access an external drive connected to the usb port of my hub from a W11 laptop.
