Message 1 of 2
Connected Wifi Disc disconnected ethernet from hub to computer now internet dropping out
Have successfully (finally) connected Wifi Disc. Had an ethernet cable from hub to computer (laptop) before.  Did speed test with ethernet connection an without. Pretty much the same, but now internet is dropping out about every half hour or so. Should I reconnect with the ether cable between the computer and the hub? Would like to use the laptop in other rooms but so far no luck.
1 REPLY 1
Message 2 of 2
Re: Connected Wifi Disc disconnected ethernet from hub to computer now internet dropping out
Is the smart hub 2 dropping out or is the laptop just disconnecting from the Internet in a different room.
