Message 1 of 3
Connecting to BT Hub USB Drive Via Web Browser
Hi
Is it possible to access files on a hard drive connected to a BT Smart Hub via a Web Browers, i.e via an IP addrerss?
Regards
2 REPLIES 2
Message 2 of 3
Re: Connecting to BT Hub USB Drive Via Web Browser
No, but you can map a network drive to //192.168.1.254/usb1 and access the files with Windows Explorer. You will have to enable SMB1 first though as it is disabled by default in Windows.
Message 3 of 3
That should, of course, be \\192.168.1.254\usb1
