Message 1 of 3
Currently lost removable password tab
Lost removable password tab from router , maybe in public what should I do ?
2 REPLIES 2
Message 2 of 3
Re: Currently lost removable password tab
The information is printed on the home hub, so the tab is not needed.
If you are concerned that someone nearby may have picked it up, then simply change the admin and the wireless password.
Message 3 of 3
if you are concerned about security then change the admin password for the hub and also the wifi password
