Message 1 of 5
DSL router recommendation
Hi,
I understand the Smart Hub2 doesn’t do bridging mode.
I have a TUF GAMING AX5400 GAMING ROUTER but this doesn’t work – from what I understand because it isn’t an xDSL router.
So I need an xDSL router, right?
I want to be able to priortise my PC connection and throttle my firestick (Netflix) and other devices. You could do this on the AX5400. I believe this is QoS? The DSL-N66U appears to have this setting.
Have other successfully used another router like this? Any recommendations? Some of the gaming ASUS ones are quite expensive but the DSL-N66U is around £100 on Box and is in budget.
Does anyone have any recommendations for a router that would work well for this?
Thank you.
4 REPLIES 4
Message 2 of 5
Re: DSL router recommendation
Just get an Huawei HG612 Openreach modem from eBay instead and continue using your router
Message 3 of 5
@HS2010
You can use the SH2 as a modem effectively.
I've had to use an SH2 for digital voice but use my Asus DSL-AC68U for the real work. Basically the SH2 forwards everything on all ports to the Asus & the Asus handles everything else.
Saves buying any more equipment.
Full instructions can be given if it's of interest.
Message 4 of 5
What sort of Broadband do you have? Is it ADSL,  VDSL, or FTTP, or something else?
If you router is not xDSL, what does it support, PPOE?
Message 5 of 5
Hi Tim,
Saving buying any more equipment definitely sounds like the best option!!!
I'm not a technophobe but not had much experience with networking. So, might need a bit of a hand along the way if you can. I guess starting with how to set the SH2 to forward everything on all ports?
I'll dig the ASUS router out the garage and have a crack this weekend.
Thank you very much, Harry
