Message 1 of 4
Data or device monitoring.
I run a wired server which is seeing drops from around 12am - 12pm each day. I’ve tried different devices all encountering the same issue. Is there a way to see if a device is congesting my network limiting the connection to other devices?
I’m on fibre 900 and get between 950 - 1050mbps to the router.
3 REPLIES 3
Message 2 of 4
Re: Data or device monitoring.
Hi @jaymorley
Welcome to the Community!
It's unlikely that you would be able to discern if this was bing caused by any one device in particular, without disconnecting each device in turn, and seeing if you still have this issue.
It might be worth giving our team a call, and they can see if there is anything else that might be causing this.
Rach
Message 3 of 4
Thanks for the response. Appreciate it’s not your fault (just voicing my surprise) but thought there’d be some way of finding out if something was hammering my broadband. Other than literally unplugging everything.
Message 4 of 4
You might be able to see this when you access your Hub Manager, so it's worth a try @jaymorley.
Rach
