Message 1 of 6
Business smart hub 3
Hi,
If I buy ,from a third party a Business smart home 3 will it work on my home system.At the moment i have a smart hub 2 and I underdstand this business hub has wifi6
5 REPLIES 5
Message 2 of 6
Re: Business smart hub 3
It does not support BT Digital Voice.
Message 3 of 6
don't think it works with digital voice if you have that
Message 4 of 6
Thanks,I do have DV.But other than that should it work.
Message 5 of 6
Thanks for your reply,i do have DV but other than that should it work
Message 6 of 6
You may have issues authenticating it, but as you have DV, then its no use.  Probably best to find a separate wireless access point, or mesh which has Wi-Fi 6.
See https://www.tp-link.com/uk/home-networking/deco/deco-x60/
