Message 1 of 2
Destiny 2
Not expecting any solutions however cant help to see if anyone else is having similar issues.
I have very high ping on destiny making it unplayable its good on every other game and cant find any reason or solution to fix it was wondering if anyone might have had similar issues and know of a fix
1 REPLY 1
Message 2 of 2
Re: Destiny 2
Destiny 2 uses Peer 2 Peer for online play, although I dont play the game this isnt an ideal way to host online matches/games, being Peer 2 Peer you could in some cases expect someone elses dreadful connection to have a detrimental effect on your own. There's quite a bit written about this online.
A far better model is to have a hosted server that all users connect to separately, but im sure there are some advantages to the Peer 2 Peer model which perhaps avoids the issue if the hosted server is a million miles away.
In fact maybe the other games you are playing use Peer to Peer also and its just luck of the draw.
If you are using WIFI connect via Ethernet, will improve things if you aren't already from a baseline point of view.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
