Message 1 of 6
EE HUB Unreliable
BT Halo 3+ was installed last week together with the EE hub.  The EE hub worked on the day of installation but since the it has been totally unreliable - solid green light for hours, red light, flashing blue, you name it, but very rarely the solid blue light it should show.  It's cable-connected connected to the BT hub and I've tried everything I can think of.  Any ideas anyone?  Thanks.
5 REPLIES 5
Message 2 of 6
Re: EE HUB Unreliable
Hi @Tinnoch welcome to the community and thanks for posting, I'm sorry to see you're experiencing issues with your hybrid connect equipment. Please can you try these steps?
Disconnect the Hybrid Connect from the Hub, then perform a Factory Reset on the Hybrid Connect by pressing the pinhole reset button on the back for 15 seconds. Once the circle starts flashing green, connect the Hybrid Connect to the Hub via Ethernet and then leave for 30 minutes to set up.
Neil
Message 3 of 6
Thanks for that NeilO, but it didn't work, the Hybrid Connect still shows solid green and has done for the past 2hours.  I rang BT and they agreed that I appear to have a dud so a new one should be with me on Monday.
Thanks again for your help.
Tinnoch
Message 4 of 6
Hi @Tinnoch
Thanks for trying the steps in NeilO's post, sorry to hear it didn't work.
Please post back to let us know how you get on with the replacement.
Stuart
Message 5 of 6
Hi StuartH
The Hybrid Connect was delivered on Saturday (excellent service) and I installed it the same day.  It has been stable and working well ever since. A good result.
Tinnoch
Message 6 of 6
That's great to see @Tinnoch.
I'm glad this one is working as it should be.
Thanks for letting us know.
DanielS
