Message 11 of 12
Re: EE Merger
ah no sorry it is just the BT WIFI and BT WIFI-X that have been renamed or replaced with EE WIFI and EE Wifi-x.
Your original hub SSID BT-XXXXXX ( what ever) should still be broadcast as well as the EE wifi ones.
If you have restarted your hub try switching the WiFi off and back on on whatever device you use to see if it shows the original SSID
(i suspect you may have other replies during the time it took me to type and post this one)
Message 12 of 12
Re: EE Merger
Thanks everyone for your replies. As a last resort I did a factory reset on the hub and all is working again with the original Hub6 SSID. The EE SSID doesn’t appear anyone. Very strange indeed!
Thanks again
David
