Message 1 of 13
EE Router Password
Hi All
BT have changed me to EE and sent me a new tv box and  router but it will not let me have the old Username and password, it says too short and not secure enough.
I have a lot of devices  like storage batteries, Inverter and many cameras and it will take hours to transfer all items.
So, if  I connect the new EE Router to the internet then connect my old BT Smart Hub2 to my EE Router with an ethernet cable will all my devices auto reconnect, I can then transfer all my devices to my EE Router over a few days
Thanks in advance
12 REPLIES 12
Message 2 of 13
Re: EE Router Password
the new BT SH3 is the same but if you continue past the warning then it lets you use your chosen SSID and password possibly EE router the same?
Message 3 of 13
Broadband
Hi All
Thanks in advance
Message 4 of 13
Re: Broadband
Read message 2
Message 5 of 13
Re: Broadband
Sorry about posting it twice but it said not posted and correct errors when I did it posted it again
Could be me !!!
Anonymous
Not applicable
Message 6 of 13
Re: Broadband
if you want to use the old password login to your new router and change these other wise red the label on   the underside ee ones have a slide out panel in thhe router with a card on
Message 7 of 13
I tried it and half the devices did not connect
I Googled it and I think I need to enable WAP2 and run a separate system along side the normal WiFi
I have put it back as it was for the time being, it's a bit confusing for someone 70+
I might just "leave well alone
Message 8 of 13
You can add the older router name and Wifi password to the EE router and then the devices will connect.
Go to Wifi and set it up as Compatible wifi.
Richard
Message 9 of 13
This explains what to do. Scroll down the page to get to the hub bit as the first bit is about using the EE app.
https://ee.co.uk/help/broadband/manage-use/how-to-set-up-compatible-wifi?
Message 10 of 13
Thank you
Did it and it worked
I was as also able to set up guest wiifi
Not bad for a 70+
Thanks again
