Message 11 of 15
Re: Enabling UDP ports for CCTV NVR
Thanks for your efforts!
A few things to investigate there so I'll have a play this evening and let you know.
Message 12 of 15
So, to answer my own question, issue is now fixed.  After contacting Reolink and some back and forth, they sent me a new firmware file which fixed the issue. It was a version that the Reolink client didn't suggest when "check for upgrade" was run - but not too bothered now the issue is sorted.
Thanks to all for help!
Message 13 of 15
Don't forget to turn on the extended upnp security again, if you haven't already.
Out of curiosity... Do you now see the greyed out upnp rule on the port forwarding screen?
Message 14 of 15
I had.....,  and yes, I do now see the greyed out entries you mention - I think their new firmware tweaked a few things!
Message 15 of 15
Would you please share this  version of firmware . I am having the same issue and Reolink  customer service is not cooperative . Thx
