Message 1 of 3
Ethernet Cables
Hi, was just wondering if you can still use an outdoor ethernet cable inside a house?
Is it safe etc, will it work just like an indoor Ethernet cable?
Thank you,
Tom 🙂
2 REPLIES 2
Message 2 of 3
Re: Ethernet Cables
@Tommy69
Its perfectly safe, but you will not find it as flexible as indoor cable, because of its tough exterior covering.
It will work just the same.
Message 3 of 3
Re: Ethernet Cables
Thanks very much Keith, really appreciate it!
