Message 1 of 3
Ethernet cable length
I have a  BT Smart Hub 2 in a ground floor room but am considering relocating my PC to a first floor room which is diagonal to where the router is.
Is there a maximum length of ethernet cable I can use or is the length totally irrelevant ?
2 REPLIES 2
Message 2 of 3
Re: Ethernet cable length
Cat 5e or above Ethernet cable can be up to 100 meters
Message 3 of 3
100m is the technical spec.  Working techies don’t usually push beyond 85m.  For 5e to maintain 1Gb/s at 100m needs good quality cable with a perfect install.    Cat 6 will manage better at extreme distances.
